JoshT
- January 15, 2011
- Middle Georgia
- 1999 Ranger
Yes, the thread changed. Was originally asking about collector exit size, but found other posts around the forum that confirmed what I thought I'd found in the past. TM headers use a 2.25" ball type collector. I've got OBX, but they SHOULD be the same since both are made to connect to stock pipes. Finding that answer created new questions, so why not revamp the thread to make more sense.
Getting full new exhaust put in my 99 Ranger V8 swap. I'm planning to go header back 2.5" with forward cats in place. Don't particularly care about rear cats since everything behind the transmission crossmember is going to be custom and they can be added back if I ever needed. In my searching for information I discovered the mandrel bent Magnaflow cat pipes.
Are the Magnaflow cat pipes actually 2.5" pipes behind the header extension?
I can't find any measurements listed online for the magnaflow pipes except for 2.25" inlet which matches the collector, but the pipes look like they step up behind the collector extension. Honestly even if they are only 2.25" they'll probably be flow good as the crush bent 2.5" I'll find at the local exhaust shop. I've seen the threads talking about the poor welding on them, but again I think it is as good as I'd find at the local exhaust shops, or atleast the ones I'm willing to pay for.
The guy that quoted a starting price of $1600 without cats is not getting my money, but with that number I don't think that he wanted it. He also tried to tell me that there isn't room for them without looking under the truck, and that I was already breaking federal emissions laws from just doing the swap. That's a story for another time, or never.
There seem to be two different cat pipe styles on the 5.0 Explorers, what I find onlines says 3 piece for the 96-98 and 2 piece for the 98-01. My 2000 donor had the 2 piece, but then my old 98 donor did too. Anyhow the two piece splits left and right bank with each side containing both cats in an assembly. The three piece has the left and right primaries separated, then the secondaries combined into a third piece. Not that y'all needed the explination, but it's leading somewhere.
2 piece setup is around 800 per side. Three piece I can find for 200 right, 500 left, and I wasn't planning to use the rear cats anyway. So about 1600 vs about 700. I think you know where this is leading.
Is the layout of the 96-98 cat pipes similar enough that it will fit on the 99-01 explorers without issue?
If I have to have an O2 bung relocated it isn't an issue since I need to have one added for wide band anyway. I'd much prefer to start with that, over buy the 98-01 pieces and tossing the rear half.
Even if I bought the 98-01 and kept the rear cats it was propably going to have to be reworked to clear the next crossmember behind the transmission. When I installed the two piece setup into my 99 Ranger the rear cats were going directly into that crossmember, since a full exhaust was coming they got deleted rather than spending the effort to reposition them. I also wanted to have flanges or clamps put near the transmission crossmember anyway to drop out the forward section for transmission work, so that would have been another modification to the later pipes.
