Robert_P
- November 12, 2015
- 1999 Ford Explorer
Working on replacing the driver side UCA on a 99 Explorer - are shims needed to make sure it's tight enough to prevent the bushing case/shells from shifting? As far as I can tell up and down movement of the arm should be from stretch of the bushing material, the outer case shouldn't move. The stock UCA didn't have shims, the replacement is the same width but I'm having issues making it tight enough to keep the bushing shells from moving.
Thanks for all input.
