wdwacht
- February 22, 2007
- South Redondo Beach, CA
- '97 Explorer Sport Manual
Shifty Shifting Resolution!
Greetings! Ok they fixed my truck after ten days in the shop. As it turns out the slave cylinder was the culprit! Dammit! It just wasn't working properly albeit it was not leaking and did not show any malfunction signs. Everything else was checked again and replaced under warranty except for the slave cylinder which turned out to be the bad guy. Now it shifts so smooth I could just ummmm well you know
beers to you!
Will
beers to you!
Will
Greetings, I have exactly the same issues even with a new clutch just installed and the internals check out. It's a beast to get into gear when it doesn't want to go; warmed up. The transmission guys said everything looks good, gears and all. And there was no evidence of fluid leaks. I'm wondering if maybe it's something in the shift linkage that hangs up, otherwise I've not a clue. This is my biggest complaint with my otherwise reliable lil buddy. Any ideas? I'm having it rechecked next week. And if a solution comes forth then for just $19.95 and a free Turnip Twaddler, no make that two Turnip Twaddlers, plus free shipping I'll send you the solution.
enjoy the weekend,
Will
