manufacture date | Ford Explorer Forums
manufacture date
JGAMBLE
Ft. Wainwright, Ak
1994xlt
Ok so I'm working on the X last nite when I look at the Date placard. I decide since she's been one of the more dependable X's I've heard about to check to see when she was made. The manufacture date was 10/94. Weren't they building the 95's by then??? or were the 95's like the 70 1/2 camaro, late in being introduced? Also decided to blow some carbon out and floored her for about a mile straight, she didn't overheat, but got real hot. Just did the cooling system a year ago, any ideas?
:chug: :chug:
Ah. yopu probably have one of those "freak" 94s then. Do you have the following in it?
1. The cupholders that aren't sde by side, but instead are one above the other.
2. In the driver side rear cargo area, do you have a little plastic pice inserted in to the side wall, by the rear side window, which does nothing?
Most late 94's have those 1995 pieces in them...
well the cup holders are the one above each other and yes I have the little plastic piece. Guess this means she's one of Ford little Freaks eh??? pretty cool. Gonna switch to a 180 thermostat soon on the heating issue.
:chug: :chug:
6 meaning June is the switch date
10/94 is a 95
10/94 is a 95
yeah thats right...... mine is a 94, but also has the one above the other cupholder, and a plastic insert where the door lock switch is in my moms 96...... build date on mine is 12/93
You must mean 12/94. That 12/93 date would make it an early 94, so it would still have the double cup holder and such....
no, my truck was built december 93....
Well, that is weird. You must have got some protoype 95 pieces in there, as my Dads' 94, which was built 6/94 has the old 94 pieces. All police vehicles have the build date in the 6th month. In essence, I have one of the last 92's made....
Mine was built 11/93 and has the old dual cupholders. I'm kinda glad it doesn't have the 95-style cupholders.
well there's not doubt mine's a 94,brickhouse styling, ttb and all. just wonder how she got built so late in the model year??? Guess maybe somebody found it partially assembled and felt pity for her??? yeah, right:rolleyes:
:chug: :chug:
JGAMBLE where was your truck built? Check the VIN#, one of the digits will tell which factory it came out of (can't remember which one offhand--at home I have my VIN decoder). Maybe Louisville, KY or Dearborn, MI. I'm just curious since it's such a late production date 94.
I am pretty sure ALL first gens. were built in Louisville Kentucky....
10/94 is a 95
So does that mean my '94 (built in 6/94) was one of the last? Cool! :D
All of the 1st gen's I've ever seen were made there. Still I'm surprised it was all in that 1 place. What if they got bombed? :) Ford needs to disperse production, you never know what could happen.
I think if they actually got bombed, they would be worrying about other things than building Explorers. They would probably be building tanks at that point...
I'm guessing I have one of the first '94's since the build date is 10/93... a full year before JGAMBLE's 94.
Actually, the check digit before the last sequential numbers in the VIN is the easy way to tell what part of the years run your Explorer is from.
The letter starts at "A" at the beginning of that model year, until 99,999 units are made, then it changes to a "B", for another 99,999 and so on. If you have an "A", then it is an early vehicle. I have D, one of the last 92's, I believe.
all explorers, rangers and mountaineers are made in Louisville, KY
Nope! Mine was made in St. Louis.
Mine was made in Louisville Kentucky. got a sticker to prove it as well!
