Master clutch cylinder | Ford Explorer Forums
The exploder
Idaho falls Idaho
1993 sport
Could anyone point me in the right direction to get some direction on how to putt a master clutch cylender on.... I have replaced everything else and i am still getting air into my system...... Thank you in advance
James
What was the original problem and what was replaced? These systems are difficult to bleed once you introduce air into them. When you say you are 'still getting air into the system', does that mean the pedal won't come back up properly? If so, has it ever worked since you started replacing parts? If not, I suspect the system still needs to be bled.
we have bleed it about 5 times now it always lasts really good for a few days. we have replaced the clutch and slave cylender basicly everything down in the tranny is new.....
bump for the early morning late night crew
Master Cylinder Install
Good Luck!
