LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
I am in the process of flushing the cooling system after just getting the truck started after a long time idle. I charged the battery before starting up again but now I notice that the battery level is low. I put a DMM on the terminals with the truck running and I only get 10.8 volts. I was not in the truck revving to ~1000 rpm as I usually would be for that test, but that is still way too low.
I am wondering if there is anything I could have disturbed or disconnected to cause this, or do I just have a mostly dead alternator? How would I check? I have never noticed any issues at all with the alternator so it seems a bit odd that it should just suddenly not work. The battery is less than a year old and is a good battery. I had no issues when charging it. I don't want to get a new alternator unless I need one. I hate spending the money only to find that I have not fixed the problem.
If I do need an alternator, are there any suggestions as the the brand and model?
Here are some from part brands that I have used before and like,
Reman DENSO 2105313 130 Amp w/o Black Rear Cover, w/ 4-groove Serpentine Pulley ($104.79+ core)
Reman BOSCH AL7541X 130 Amps, May Not Include Pulley ($108.79 +core)
New ACDELCO 3351118 Gold 130 Amp, w/o Black Rear Cover, w/ 8S Pulley ($126.89)
New ACDELCO Gold 3351156 130 Amps, w/ Black Rear Cover, w/ 6S Pulley ($140.79)
The ACDelco reman is only $5 less than the new part so I wouldn't bother.
Do the listings that say w/o black rear cover mean that I need to save that part from my truck?
What is the difference between the 4, 6, and 8, grooved pulleys?
Thanks again for all the help.
LMHmedchem
LMHmedchem
