dumalkin
- June 20, 2011
- Explorer Limited AWD 2012
Hi,
Got my Ex Ltd back from half-year maintenance. Without asking or mentioning it, they upgraded to 3.5.1 (understood it after trying to solve the "why this damned phone can't connect to the Sync" problem).
Ok, honestly, I'd try to upgrade anyhow sooner or later, but still - would expect from them at least warn me about the upgrade.
Now, about problems in the new version:
In my previous version, when ignition is switched off while playing some song from SD card, MFT somehow remembered the song, and later, when turned on, would continue from the same place.
Now, 90% times it starts playing the right song, after 1-2 seconds writes "indexing device", then stops playing. I can manually go to the "browse" menu, choose whatever I want, and play it again.
Remaining 10% times it starts right with the first song on the SD card, with the same "indexing device" notice.
Another bug is the "back" behaviour in the list of folders on the SD card:
If I select folder (say "Madonna") and get list of sub-folders, and press on the back arrow instead of entering one of the sub-folder, I should get to the list of all top-level folders ("Madonna" is one of them). instead of that I get main list with "Music" and "Browse" entries.
Didn't try it with USB, but with SD card the behavior is broken.
