Does anyone know if the middle seat in the explorer/mountaineer can be swapped out to the 2003-2005 middle seat that has the shoulder seat belt? I wanted to get rid of the lap belt in the middle of my 02?
i think that the leather is different from on the mountaineer depending on the trim levels/2 tone etc. and the explorer I believe is different altogether.
I'm pretty sure that it would work, but it may be a different color. You may be able to swap the seat covers and modify the upper one so you can use the seat belt. And 02-05 interiors will all swap. I put a complete interior from an 03 with a third row into my 02 without one. The only problems were swapping the studs in the floor to bolt the seats in, and rewiring the front seat belt pretensioners because the plug is different. Also, you have to swap the carpet because it's different.
