Camarofan
- April 23, 2014
- South Dakota
- 1997 Ford Explorer
So, i've gotten to the point where i'm going all out, and i'll fix whatever i break over the winter. I've gotten the torsion bar off the little catch bar the bolts go into(I can't think of the name right now) The other problem is, the bar doesn't droop at all, How would i remove the torsion key to flip it?
Next, has anyone used the 3inch drop leafs that Airbagit has? I'm already running a 3.5inch block on a 225/70/R15 tire, and i plan on another 1 inch drop for it.
Also, http://www.airbagit.com/product-p/key-fr-07.htm
Would these keys be the same as the drop keys they offered awhile ago? Or, even fit for that matter.
Finally, do they make swaybar end-links for these truck? front and rear preferably. I read something about using F150 links for the rear.
And does anyone know if there is a dual shock mount available for the rear? I have a set of air shocks on it now that work pretty good, but i'd like a bit more stiffness.
