Misfire help | Ford Explorer Forums
Misfire help
blueka
Elite Pickler
Location
Liverpool
UK
97 UK XLT, 99 Sport V8,
Ok here we go.
2000 V6 SOHC.
126 miles
LPG (propane)conversion. Also runs on petrol (gas)
When on petrol there is a misfire in cylinder 1.
When on LPG it's fine.
It's just had a full service (plugs /wires / filters / fluids)
I'm inclined to believe it's an injector fault.
Any help / advice / pointers would be great
Si
I’d swap in a used, cleaned injector, or pull the one in it and try and clean it and test the spray pattern.
You can make a fuel injector cleaner/tester at home from a tire valve stem and some other bits.
Swap the injector position with one from another cylinder to see if the problem follows the injector... of course you'll want new injector o-rings.
One thing I wonder is if switching to LPG, does this let traces of old gas sit in the injectors and gum them up? If so then a quality fuel system cleaner might help.
It's not my explorer. I'm working on it for a guy who sent it to a shop for them to fix when it started running rough. It sat for months.
They cleared all the codes and I've done a bunch of work on it to get it road legal again.
They said it had misfire cylinder 5. It had a cracked plug.
Now that I've had it running again, it says misfire cylinder 1.
It's getting returned to him on Saturday as is, I can't get the parts here in time. So it'll have to wait for another day
Si
