Mobil 1 differential fluid OK? | Ford Explorer Forums
MikeTEC
Central Texas
2004 Mountaineer 4.6L
Going to change the rear differential fluid on our 1996 5.0L 2wd when the axle is removed. We want to use Mobil 1 synthetic.
Is the weight of Mobil 1 OK for this model year? It has a 3.73 limited slip axle. Additive needed?
Thanks for the help! Mike
I ran Mobil 1 in my diff for a couple years ( before switching to Amsoil ) and had no problems whatsoever. I never used any friction modifiers either.
Good luck .....
Al: Good to see you on the board again! Hope things are well with you. Thanks for the advice. Mike
