koda2000
- September 2, 2011
- x
first, let me say that i don't want this thread to get into other brands of oils as there are many opinions as to which oil is the "best". i've aways used Mobil 1 in my Corvettes and street rods and i've been very happy with it.
i understand that Mobil 1 EP is supposed to be able to allow you do extend your oil change intervals to up to 15,000 miles. i've started using Molbil 1 full synthetic in my trucks, as it's the same price as Motorcraft synthetic blend at Wally-World (around $25 for 5+ qts). i know EP is supposed to work by being able to suspend more dirt than regular oil, and also not break down as quickly.
i would consider using EP on my daughters trucks, as i don't always have access to them when oil changes are due. i will continue using regular Mobil 1 in my '01 EB as i always have access to it.
some have reported leaks after switching to full synthetic oil. all 3 of my v8's have slight rear main seal leaks, but none has gotten any worse since switching to Mobil 1.
Question: i would assume that even though you might be able to go further between oil changes you should still replace the oil filter at normal intervals. right?
