cantspell
- November 12, 2002
- Toronto. Canada
- 1998 xlt
Hello,
So i'm been having chronically bad fuel milage. I"ll first give an update.
I have done a full tune up and a fuel injector flush, only think i didn't do very well was clean the MAF, but i did it which i'm sure is better than nothing. I also has the computer reprogrammed for my tire size, which is 31",however i'm sure after disconnecting the battery, this was 'undone'.
I have a magnaflow and filter on (which i know will reduce economy). And i have 3.55 gears (which suck) and a bush bar on the front.
I am getting about 325km to a full tank, or about 200mi. With mostly city driving and unfortunatly it's usually very short trips, is this normal?I"m essenttially getting just over 12mpg??? What gives???
Assuming my engine is running well, which both I and the Ford dealership say it is. And taking into considerations that i have adopted a conservative style of driving
. In fouth gear (with the over drive off) at 65mph i'm at about 2600rmp, which i know is high, but I can't possibly lower my gears, as i already have 31" tires on and acceleration is slow (and when i measured the speed, i took into account the variance the tires produce). So what is it? any ideas?
I think, some of it could be due to the performance air filter and exhaust, however, I also think that a change to my gearing might help, but considering my already over the 'ideal range' - what should i do? Swap out my magna flow?
pls help! Matt.
pls help! Matt.
