2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Housing & spacer applies the tension
That's correct. As the tensioner is screwed in the piston is forced completely into the housing. The housing then presses against the spacer that pushes against the guide.
Dale,
With the present way you have done it. The piston will depress all the way to the socket with 20 in lb's of torque....Right?
So if it was a solid bolt it would still be torqued to that value?
Cliff
