fabianoliver
- July 28, 2022
- Montevideo - Uruguay
- 1994 XLT
hello good evening!
I have a 94 explorer 5 speed manual.
The engine behaves strange in some situations:
If I go push hard in first gear, and then I put the engine into neutral, it keeps idling at 2000 rpm.
If I turn it off and on, it idles normal, at 600.
If I drive slowly without accelerating too much, at traffic lights the revs drop to 600.
When driving between gears, the rpm do not drop to 600, they remain at 1300.....
If I release the accelerator, the engine continues pulling slightly (it goes at 1300 revs) for a few seconds, and then drops, and you feel that the engine slows the truck.
I already changed injectors, air and gasoline filter, I cleaned butterfly and changed the IAC valve, spark plugs, and cables.
What could be happening? consumption in the city is BAD,
10.5 miles / gallon.
In freeway seems ok: 19
what can happens? Any ideas?
i want the truck as others cars, as soon as you take off the foot off the accelerator, the engine stops pulling.
Cable in the butterfly seems relaxed, doesn't sticks
Any ideas?
Thanks!!
Any ideas?
Thanks!!
