Foggman
- February 20, 2005
- Virginia Beach, VA
- 1994 2dr Sport
Has anyone ever had any problems with their motor mounts coming loose or failing? I have been tracking down a rattle I hear comming from the left front of the truck...I have eliminated all possibilities and have concluded that my driver side motor mount is shot. WHen you look at it from the front you can see the bolt that goes up that holds the mount to the frame and the bolt that goes down that holds the engine to the mount. you can also see a "pin" of some sort that goes from the top half of the motor mount to the bottom half. I can pretty much replicate the sound I hear while driving just by messing with that pin (much quieter though..I attribute that difference in noise level to being quieter when I shake it my self cause I cant put as much touque on it as the engine can). Anyways, I cant pull the pin out but I can twist it freely and move it side to side. So what I am thinking is that the rubber inside the two halfs of the mount has either crushed down enough so that the two pieces clatter around a little bit when I go over a rough section of road or has dried out so much that it is falling apart on the inside of the mount.
I have already ordered both motor mounts and I will be replacing them tomarrow. Are there any tips that anyone can think of that I should be aware of or concerned about? I plan to support the engine under the oil pan with my floor jack and a 12" x 12" x 2" block of wood..
Any comments or concerns or personal experiences welcome!
Thanks
Lance
Thanks
Lance
