Here's the thing though: The front driveshaft is turning all the time. The CV head can't cause bind-up only when turning. If the CV is binding, it's going to bind all the time, not just when turning. When bind-up occurs, it's going to make the front driveshaft make more noise (like mine does currently) but it's not going to cause the bind-up. It's physically impossible.
A binding CV head cannot cause driveline bind-up. Driveline bind-up is caused by a difference in the distance that the front and rear wheels have to travel when cornering. The center differential (actually a planetary gear set) in the transfer case is responsible for allowing the front and rear outputs to turn at different rates. The front and rear outputs are coupled by the viscous coupling. If the VC fails in the locked position, it will resist allowing the driveshafts to turn at different rates, which results in the bind-up (the same way a conventional t-case locked in 4wd acts).
Now, when bind-up occurs, if the front driveshaft CV head happens to be bad, it *may* cause noise from the front driveshaft. But the reverse cannot be true... the driveshaft is in no way responsible for causing the bind-up. It's just not possible.
-Joe
