I have a 2000 XLT now, but I have had a 91 and a 96, and the middle console is still fairly the same. I also have the very same 6 disc Clarion changer. Take the two screws out in front of the hinges. Also take the Kleenex/ change holder out, and take out the two screws there too. Now pull out the insert that has the CD holders in it, or it may be flat dependant on the year. Remove the first four CD holders completely with a sharp knife, (be carefull!) on the passenger side of the console until you have a flat surface. You will still have two to use beside it on the driver's side of the inner console. Remove the Changer bracket on the left side of the unit. Leave on the right one on, (this would be facing it right side up). Put the left side of the changer flush with the front of the inner console. Drill holes where the brackets would normally attach. ( You can replace this piece for under $25 if you decide later to not use the changer anymore) The factory screws are just long enough to go through the plastic into the changer. Now, one side is secure. Use the Factory Bracket to attach to the bottom of on the back of the inner console. Simply run your CeNet cord under your Kleenex holder slot through one of the CD holder places that has been removed. Put the piece back in, and put the four screws back in, and then the Kleenex holder. It should be a very tight fit. You will not be able to mount the changer all the way against the Passenger side wall of the inner console, because of the way the Clarion brackets are made. It leaves just enough space however to put your owners manual in to. This frees up some more space in the glove box. Good Luck! These instructions are for Explorers 95 and up. You didn't specify a year, so I hope this helps. I can talk you through the 91-94 too if you need it.
