Pmedic548
- March 13, 2005
- Girard, IL
- 97 Eddie Bauer
I have a 97 Eddie Bauer Explorer with control trac 4wd. It is raing today and while driving the 4WD and 4WD Low light on the dash flashed on and off several times. I then noticed that when I switch from "Auto" to High the truck does not shift into that mode, nor when I stop will the truck shift into 4 Low. COuld it be a moisture problem with water getting into something. Where should I begin looking.
Thank you
Scott
p.s. the truck still is in auto 4wd as I tried to spin the tires on gravel and the front wheels kicked in as advertised.
Thank you
Scott
