My 93 Explorer A4LD transmission is leaking. | Ford Explorer Forums
tillbilly69
woodstock, IL
93 Eddie Bauer
93 explorer a4ld Trannys leaking from what i think is called a servo seal?
Welcome to this forum! There are 2 servos with O ring seals. The cover is held in place with a metal snap ring. It's hard to get to with the catalytic converter, and the heat shield in the way, but possible. Replace both seals on those servos as well as the actual servos, and the modulator.
