Curacao Steve
- June 28, 2013
- 93 Explorer
In the Spring of 2012, a rat crawled into my Explorer and died. Now, whenever it gets warm here (it does that a lot in the Caribbean), the whole car reeks of dead rat. I looked everywhere for it, but couldn't find it. And, the smell is so pervasive that you can't get a fix on where it's coming from. Just somewhere between the front seats and the tailgate.
Actually, I have another problem that I wanted a lot of eyeballs to review, so I figured I would lead with the dead rat. Last week, I had a dead X. With everybody's help I was able to diagnose the problem (dead fuel pump) and the car lives again, but now it has a new problem. It "idles" really fast. Depending on the exact conditions, anywhere from 1800 to 2700 rpm and it bounces around a little. Wowza! But the longer the engine is on, the more it likes 2700 rpm and stays there.
At first it was throwing codes that indicated a MAF problem or a secondary fuel circuit problem. (Maybe they were left over from the earlier problem) Anyway, those went away and were replaced by a TPS high voltage problem. Checked the TPS voltages and all seemed ok, but the code persisted. Then I rigged a short from ground to the back of the plug on the TPS, but that didn't change anything while the engine was running. Removed the ground, restarted the car and it still "idled" like it was on crack. Checked for codes again and now I get a perfect score: 1 1 1 The thing is, it's still running like a cat in a room full of rocking chairs.
It surely seems like there may be one or more poor electrical connections involved, but why am I now getting 1 1 1? And what, short of removing two spark plugs, can I do to make it behave right? One probably unrelated piece of information: the voltage from the TPS sensor is 0.8V with the accelerator released. From what I've read, thats a bit low, although nobody said it was bad.
