Tunic_21
- May 29, 2011
- Muskegon, Michigan
- 94' Explorer Eddie Bauer
Hi, i have a 94 4wd 4dr explorer, i need help. back before i bought it the prev. owner but in a Viper system.
Problem: when i press the lock button it UNLOCKS the doors but ACTIVATES the alarm, and is the same then i press unlock(locks the door but deactivates the alarm)
Problem 2:
Some times when i try to start the car it tries to start for like a split second, last night i had several things go wrong, the lights where acting like i had my hazerds on but i didn't. or the relays under the dash continually click. and sometimes the relay switch locacted in the panel where the jack is located will click as well>>>.(note: i checked all of the relays/fuses and all work fine)<<<
last but not least sometimes when i go to start it the dash lights act like there was a power surge, getting brighter then normal for a second.
Is there anything that can be causing all of these problems??
i was told it could be anything from a loose wire to the Neutral Safety Switch.
and if anyone would know where that is on a 94 explorer that would help thanks.
Update: about an hour ago it did it again it would go to start then like shoving a stick in someones bike wheel ... stop. i tried diconnecting the + side battery, it worked ...for a minute. then when i reattached the + to the battery my explorer would automatically start. now i am thinking it might all have something to do with the viper//keyless start system ???? you think???
Problem 2:
