whiterabbit410
- January 1, 2022
- Portland, OR
- 19974.0ExplorerXLTCT4WD
Series of events
Is my clutch likely bad now? Or would it stand to reason that, the clutch wasn’t the problem , the huge leak and lack of fluid was, and while it certainly was bad to run it low, it did shift fine last time I got it home, that it I fix the leak the clutch may still have a few miles left ?
It made it from Florida to Oregon and I’m really hoping to stretch it a bit longer
237k miles.
- Experiencing some slipping
- Get supplies to do a poor mans flush
- Find it’s actually very low on fluid
- Add fluid, problem improves for a bit
- Drive it, flush some, add some, etc, the first drain was horribly black and sparkly
- Drive it to and from work a few times , 16 miles a day or so, gets to where I have to add a couple quarts to get it to move but makes it to the destination.
- Problem gets so bad I can’t back out of my driveway, lo and behold it is empty again
- Figuring I had not reconnected the line I used to drain it properly, I get down and adjust that
- After backing halfway down the driveway to test after adding 5 quarts, I find profuse leaking
- An entire line seems to be completely missing or detached and I’m not sure where it should connect to
