93explorereb
- January 16, 2009
- Northeast
- 93/97 4.0 EB/5.0 XLT 4AWD
Greetings:
My tensioner is at the very top! And its a weird one
! I have no way to make it pivot, other than turning it by its pulley bolt? The idler on the other hand is down on the bottom? Even the under the hood diagram shows the two to be reversed! Additionally, the tensioner has a smooth surfaced pulley, whereas the diagram displays otherwise. The donor tensioners that I have, have pulleys with groves/tracks for the belt to run on. The previous owner did some mickey mousing or something
. I am thinking of just removing this tensioner, and reversing it with the ilder pulley/base. And then attaching one of my donor tensioner/pulley assemblies. I will try to get a picture later on this afternoon. But I can assure you guys that the order is definetly reversed, in addition to the tensioner being much different from all of the other tensioner assemblies, including the one on my under the hood diagram
. What say you? Thanks in advance!
Best Regards
Best Regards
