- June 3, 2003
- Austin, TX
- OBD-1 Kenobi
Hi Yall. 1st of all, dont yell at me for not searching. I know there is a lot of transmission posts on this site, but none of the ones i searched for(a good 45 minutes) yeilded the results/syptoms i am having.
1) I have a 92 4 door 4x4, and my tranny problems start when i first put the car in gear after starting it. I put the tranny in R (reverse) and it hesitates for about 2 seconds, then goes into gear. after that, its fine.
2) when im sitting still, in D (drive, the overdrive gear), with the brake on, im idling around 800 rpms steady. if i roll my window down, i can hear a slight metal clanking noise. I dont know if its related to the tranny, but its there. its hard to describe. its like smalls bits of metal is hitting a concrete floor. best way to descibe it. a clanging sound.
3) when im sitting still with the brake on, im idling around 800 rpms steady.(keep reading, same senerio). The tranny will want to slip, i guess its called. Well, it feels like a car is trying to push me from behind when i have the brake on. the ex will want to lunge forward, with several birsts, and ill have to put in park for it to quit, when it then idles at around 1200-1400 rpm.
is it time for a rebuild, or what? i know absolutly nothing about transmissions. btw, i have 139,000 miles on this tranny. and im about 90 sure nothing has been done to it. thanks yall!
