2stroke
- August 7, 2013
- Location
- 55302
- Annandale, MN
- 1993 Ford Explorer Sport
Ok, I might have a good one for you guys. I've been having an idling problem for about a month now, and am finally ready to try and find it. I just finished putting in new intake gaskets, all three, so I know its not that. I only have three things off the vacuum tree; FPR, brake booster, and a line to one side of my DPFE to keep me from getting a check engine light. None of those seem to leak. How its running is where it gets strange. I have a manual transmission, so no vacuum is involved. Still, I can hear a sucking sound when at part throttle in 1st-3rd gear, but never 4th. Sometimes it comes back in OD, sometimes not. I don't see how it could be transmission related, maybe it just has to do with load on the engine. Still, since I can make the sound with the throttle, and it doesn't seem to pertain to RPM, I would think there is a crack in my intake duct. I can't find one. I've tried two air ducts, and even plugged the hole for the breather tube with no change. I've sprayed carb cleaner around the engine and found nothing. Another strange thing is I can't hear any leaks when I rev it by hand under the hood. It only happens when driving, and it seems to go away with wide open throttle. It has to be a good sized leak because I have my throttle plate stop screw turned almost all they way out, and it will idle at 650 rpm no problem with the IAC disconnected. With the IAC plugged in, it idles at about 900 rpm and unsteady when warm. I mean, what else is there? Its not intake gaskets, its not a hose off the vacuum tree, its not that tube that goes to the throttle body (that I assume is to burn off excess gasoline vapors), and as far as I can tell, the intake ducting is fine. Throttle body and IAC gaskets are new as well. I've never smoked in my life, but I might have to get a cigar and try as Scotty Kilmer does and blow into the brake booster line to find a leak.
