daddynuz
- April 5, 2006
- wall,nj
- 1993 explorer
I'll try and give as much details as I can. My 1993 explorer was converted professionally to R134a ran fine for a year got low on refrigerant added roper amount of r134a with a stop leak additive included. ran good all last season then High side pressure hose blew. let it alone through the winter. replace entire manifold with new. pulled a vacuum and it seemed to hold 28-30 lbs. charged system to about 40lbs compressor short cycled for a short time as gas was entering system then it ran steady till I hit 40 lbs. ran car and system for about an hour. shut down car. a few hours later restarted car and system was still switched on a few seconds after starting I heard a hissing sound and saw some vapor cumming from under the car compressor started to short cycle and took reading and pressure gauge was bouncing from 25-60 on the scale. I also did (what I thought) was a through leak test with an electronic tester did not detect any leaks when I charged system after manifold install. I was told by an old ac guy ( mostly residential experience that he thinks it is a bad pressure relief valve some where on the high side of the system. visually searched for that valve but not sure where to look also tried to search parts lists and I can not find 1 listed. Any an all suggestions for trouble shooting this system would be appreciated
