electronicsguy
- October 10, 2011
- Bowling Green, MO
- 95 Explorer XLT 4.0 4wd
Ill start at the beginning. A few months ago my explorer had trouble going into reverse and there were 2 different times that the od off light would start blinking but would go away by itself without having to reset the pcm, I immediately bought a filter and fluid and had it changed. Everything was perfect until last weekend I was going 80 on the highway and the light started flashing and stayed this time. Then the next day I did something really stupid. We were pulling a trailer with the ac on max on a 95 degree day and I would usually kick overdrive off to keep from being too hard on the tranny but since the transmission was in limp mode (i didnt realize this at the time) I couldnt switch it out of overdrive. On the way back home it revved up like it was in neutral and I had to pull over to the side of the road (im guessing i overheated the tranny) I shut it off and started it back up and it was fine other than the light flashing. I had the codes scanned the next day and I had 335 and 648, I fixed code 335 by changing the dpfe (egr pressure sensor) but the code 648 is incorrect 4th gear ratio. I had a transmission shop tighten the bands today for intermideate and overdrive but they said that didnt help and they wanted to pull the tranny apart and start rebuilding. My question is, is there any way I can check for a bad servo seal, servo, solenoid or anything else without pulling the pan off the tranny? Also if I reset the pcm and leave od off, the code never comes back and it drives fine other than my gas mileage sucking from not having overdrive. What are the chances I can get by for awhile by leaving overdrive off and there a way to make it default to od off when I start it in case I forget to hit the button one day? Also it does seem to shift into overdrive but the tach bounces about 300rpm while driving on the highway right before it sets the code, maybe a clue?
thanks
Mike
thanks
Mike
