Michigander
- February 20, 2001
- Flint, Midland, Ann Arbor, Alpena; all in Michigan
- 98 Contour SVT
NEED ASAP- Difference between 95 and 99 OHVs (motor seized)
My motor seized up on the way to work today. It's been running rough and making a piercing metal on metal sound on startup. I checked starter and the pulleys... and I think it is internal. There is coolant leaking now so I'm about 99% sure I broke a rod... like I said, now it won't start.
I have the 95 OHV and am planning on swapping in a 98 or 99 OHV. Is there a difference between the motors? Can I use the fuel injectors off of the 98? Is everything pretty much the same plug/bolt in? What does this swap require?
Anyone want to help a swap in the Detroit area???
