jrford
- March 1, 2005
- Birmingham, MI
- '10 Sport Trac
just to chime in, when i mounted new tires the Alignment Machine spec for Camber was -.03 to 6.0 degrees was considered OK. 6.0 degrees is a lot, i can actually see that, the wheel is no longer straight up/down in the well and mine was off 1.8. Try a simple bubble level to verify. According to the FSM all Castor/Camber/Toe is adjustable to some extent. I'm under the impression that shops would rather skip a camber/castor and just set toe due to the time involved. Then they might not even stock the parts necessary so mostly its over looked or avoided.
So before my next alignment i plan to pick up the kit, so there is no excuse, and specify that they fix the camber as close as possible to Zero. I want those $800 worth of tires to last - imo.
