DocRizk
- January 11, 2014
- PA
- 2002 Ford Eplorer XLS
Ill try and make this short and sweet:
bought a used 2002 XLS and the only issue I had was ABS light coming on (feels like pedal pushes back and then light kicks on), rear wheel bearing and 4x4 wasnt working. (4x4 lo would work when ignition on but nothing after that point)
So I had replaced a rear wheel bearing, rear brakes and had a dealership run my VIN for the proper 4x4 module replacement.
The original 4x4 module ended in AF and the new one in AL. So i plugged it in and BOOM... i had a truck once and for all.
2 days later we got hit with a bad storm and i looked forward to the chance to test the truck in the snow. I was driving home, up a hill and I noticed the truck wasnt really producing much power so i pushed the throttle a little harder and it reved up for a moment and then lost its engine power again and krept up the hill at 10 mph. It was idling extremely rough to the point of stalling when givin any throttle.
In the following days I deduced that the plastic plenum had 2 thumb tac sized holes melted through the top right after the throttle body. I still have no clue how or why this happened but I plugged the holes, replaced the upper intake gaskets, EGR gasket, cleaned the throttle body and MAF and also replaced the air intake filter and fuel filter. Also when the I pulled the TB i noticed the inside of the plenum was melted, right below the holes i found. Im assuming someone sprayed ether or other non plastic friendly chemical in their. No other vacuum leaks were found.
The current state of the vehicle is, well parked, but it will start right up,idle fine but still will not go above the 10mph/2000rpm mark.
The only code that was pulled was for the idle air controller, but im not sure if this would cause the issue im having and also if it was just aresult of removing these parts as a part of the process.
If anyone has any ideas as to what im dealing with please let me know and i will provide more info if i can.
Thank you
Thank you
