gijoecam
Village Idiot
- May 31, 1999
- Trenton, MI
- 98 ExSport, '00 F-150
I'd like to take a step back here, and ask what exactly the problem is with the vehicle? There are a number of problems that can be caused by running mis-matched tires, and there are a number of problems that a shop will diagnose when we (the collective knowledge accrued on this forum) know better.
So, with that in mind, what, exactly, is the vehicle doing, and when is it doing it?
What was the vehicle doing when it was diagnosed with a bad transfer case in the first place?
We also need to keep in mind that with a 96, running different size tires with the switch set to 2wd is not going to have any effect on the transfer case. It can be done safely. Now, if your son spent all his time running around in 4auto, AND the tires were, in fact, different sizes, then yes, it may be possible for the transfer case to be damaged, but unless they were severely different sizes, and the vehicle was run in 4auto for extended periods of time, AND your son had been experiencing driveline bind-up (which he should have noticed and reported long ago), it's not likely that the tires alone damaged the transfer case.
Let's begin at the beginning and go from there, OK? We're all happy to help solve the problem, but we can't help much if all you want to do is rant about something that may or may not be anyone's fault. We just want to help you fix the problem with the truck.
-Joe
-Joe
