jekbrown
- March 27, 2005
- Vancouver, WA, USA
- '91
hey gang. I have a problem with my 1991 Ex and need some help trying to figure it out. Basically, when you start it up, the RPMs quickly move up to about 3000... neither letting it warm up and/or gassing it a little bit seems to get it to drop back down to a normal idle level.. it just does it on its own at some (seemingly) random point. In any case, when I put it in gear (its an automatic) the RPMs drop to normal, but sometimes while driving they will head for 3000 rpm again... with NO driver input. Pretty scary... its like someone is pushing the gas pedal for you even if you want to slow down or stop... ya have to fight it with the brakes and/or put it in neutral until it goes away. The problem is intermitant but after driving for 30 mins or so it seems to happen less and less. The check engine light came on today on the way home from work for about a minute and then turned off.
I have only owned this rig for 6 months or so... so far it hasn't had any other major issues... just standard stuff you'd expect from a 15 year old rig. Anyway, anyone have any tips? things I should look for? As far as the check engine light, can you get a guy at NAPA or Autozone to plug in a gizmo to tell you what the computer says or do you have to take it to a mechanic and pay some ca$h? I like to do auto work myself when I can (yeah, Im poor) so hopefully it won't cost tooo much.
any help would be greatly appreciated, thanks in advance!
j
j
