SIRIUS198
- October 30, 2008
- Calgary, AB
- '01 Explorer XLT 4.0 SOHC
Quick bit of info on my trucks issues. 2001 XLT 4.0 SOHC with about 168,000 km. While idling the truck apparently started chugging and then stalled out. Now its a no start. Everything happens when you crank except no vroom as the wife put it.
relay > good. confirmed by switching with horn relay
fuel shut-off > button is down
fuel filter > replaced with new
With the tank out of the truck I rigged up a couple of jumper wires from a spare battery to the pump, it was still all hooked up inside the tank, and it pumped right away. I then took the sender unit out and connected it to the wiring connector on the frame rail. Turned the key on and she started buzzin'!
My pump is working, now, but I can’t confirm it was before I dropped the tank. Short of putting the tank back in the truck to see if it starts I'm almost stumped.
2 thoughts:
1) pump was not working before I dropped the tank but after bumping it around and handling it, it started working again.
2) pump was working all along but not putting out enough pressure to run the truck. I didn’t time it but it took a minute or 2 for it to fill a 5L gas can.
In either case I believe I would need to replace the pump.
Any other thoughts or things I am missing or overlooking? Could it be something else completely?
2 thoughts:
