whistlingwind
- October 13, 2007
- los gatos, ca
- 2001 mountaineer 5.0L
I read my Key On Engine Off code using this scanner I rented from autozone (thanks to this forum for the tip!). I was able to read my KOEO code (loose gas cap) and clear it.
But I can't seem to run the Key On Engine On test and could use some help.
The procedure I read about says "after the engine code is sent to turn the wheel 1/2 turn, press the brake, cycle the OD button". I am assuming you have to do this correctly to trigger the test to start running.
But the scanner does not seem to pick up the engine code, thus I don't know when to start the user inputs (above). I pressed the 'read code' button on the reader and it says 'passed', however I really don't know if the test ran at all.
So my questions are: how does one start the Key On Engine Running test (the above sequence of steering/brake, etc?) and then actually read the codes?
Thanks.
Thanks.
