scottdash8
- December 30, 2007
- nc
My daughter has a 93 Explorer with a 4.0l v6. The car idles just fine, but when you quickly accelerate from a stop the car will not go faster than 15MPH. If you rev the car it will stumble and not go past about 1500 RPM. However if you slowly accelerate it will go to 6000 rpm. On the highway at 60MPH if you step on the accelerator is will stumble and decelerate as long as the pedal is on the floor,but if you let off it will begin running fine. I changed the fuel filter and I am going to work on the Injectors, and ignition next. I'm stumped. I searched this forum and could not find the same problem. Any advice or direction in this forum would be appreciated. Thanks
