Need Help/Transmission or Tranfercase | Ford Explorer Forums
siersf250
02 AWD Mountaineer, Ok, so changed out the transfercase because all 4 tires were fighting with each other. Also, binding up and making a popping noise in the front. So I took out the front driveshaft which made the binding stop but still has a slight possi affect in the rear. SO I put a "new" transfer case in it. But before i could put in the front driveshaft it won't stay in park. On a hill it will have a slow slow roll to it Starts fine, shifts all gears, go's right into park. Messed with the linkage but it is fine. Is the transfercase i bought a bad one? What keeps this suv in park?? It was fine without the front driveshaft in it before, never rolled. My transmission was rebuilt and fine before i did the transfer swap. Any help would be HUGE! My mechanic is even a little stumped. I did read about a clutch pack for the rear? But one thing at a time
Welcome to the site.
Just read that thread. Mine is an 02 mountaineer AWD but might still be basically the same. It confused me because it never rolled on me before. Maybe the old transfercase was locked up and causing my binding. Thank you
