Mom Mechanic
- December 12, 2011
- 2002 Explorer 4.6L V8
My Explorer is a 2002 4.6L V8 EFI that is confusing a few people. I will try to explain my problem. It will start fine with all gauges looking good, then after a few seconds the idling seems to go up, when I place it in Drive the engine dies. I try to start it, but it just cranks and won't turn over. I take out the plugs and they are wet with gas ( some worse than others). I clean them, then the same thing happens again. I have put new plugs in. I took the MAF off and cleaned it very carefully with MAF cleaner. But earlier a neighbor sprayed carb cleaner into it and the throttle intake. Also I should mention that it is not throwing any codes. Any help would be greatly appreciated
