- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
I just put a new clutch and slave cylender in my ranger and now I cant get the clutch to work at all. I tried bleading the slave before I put the trany in. I have tried the gravity feed deal and I dont get crap. I tried the catch can into fluid with the beader valve, nothing happens. I am wondering if the master cylinder part is bad. The resivour seems to not be loosing any fluid as you pup and I am getting very little air/fluid coming out the bleedervalve. When I disconnect the line at the tranny and pump the pedal I get no build up in pressure eather.
Prior to doing the clutch I was having problems with the clutch not disengaging. It looked like the slave was leaking due to brake fluid coming out of the bellhousing. Plus the clutch was pretty toasted anyway so its not like it was a complte waste. I hate to throw more parts at it with out knowing what the real problem is. I am at a lost. I only have about 8 hours into trying to get the damn thing to bleed.
