pepeancon
- August 3, 2004
- UNION
- 1998 XLT
Hello there,
My 1998 V8, AWD is leaking Burned Differential oil from the Front Differential, Is there a escape line on top of the Differential? there is also a bad noise coming out of the Front Differential at 30-40MPH, I also need to know what is the Standard RATIO for all the V8 [1998], AWD, is it the same as the REAR? I know where to find the Ratio Code, off the Drivers side, but is that RATIO for both Front and REAR the same?
I'm thinking to Replace it for another one, if the Differential went out, or should I change the pieces inside the Differential is it bad? what is your recommendation, I can't drive like this, I have replaced the oil about 3 times but nothing, it Burns it fast and leaks.. HELP! what is bad? and if there is a way to disconnect the AWD? thanks a lot
pepeancon from NJ
pepeancon from NJ
