need help | Ford Explorer Forums
need help
eleetham
ca
87 ford ranger
i have a 1987 ford ranger pick up truck....i notice a hose hanging from driver side rear axel is that vent hose now my only question i have does the other end is it connected to anything.
...I sure wish I could understand what I'm reading here...:scratch:
...Your surgery picture didn't come thru...Try using a picture storage site like imageshack.com and then link the pictures here..
its only the axle vent hose its attached to the chassis on the left side but clip is probably rotted off on the end of the hose there should be a cap if not use a body push pin and you can tiewrap it to a spot on the chassis
re:
is it still safe to drive that is my only car i have to get around so i can get to and from to my doctor apointments
...From the picture, it is a vent tube and you are safe to drive..;)
...I have seen people mistake their brake lines, and parking brake cable as nothing to worry about thinking that they were the vent tube...
...Where in Cali are you???
yes its safe its only a vent it should be tie up above axle this is a 2 minute repair tie it to chassis if it was a problem it would be leaking fluid
Jeez I wish the underside of 23 year old Michigan cars looked like that... :)
i was thinking it was just me maybe its a 2007 not a 1987
...Pm received...Talk to you in a bit...:D
