springer9861
- March 20, 2004
- Central Ohio
- 91 XL
Started to put new rear drum brakes on my 91 Explorer and I got the right side apart O.K. Put everything back on but I'm having a problem getting the break shoes to come together at the top where it meets the stud. It acts like the brake cyclinder is holding them apart. My question is: do you have to compress the brake cyclinder on the rear drum brakes like you do the calipers on the front disk brakes? I took the left side hub off so I could match everything up and they look the same. I can't get the hub back on without getting the break shoes closer at the top stud......Thanks for any and all help....Larry
