Dan Whitaker
One fast putty tat
- December 24, 2001
- Raytown MO (Kansas City suburb)
- No Mounty no more.
I have been hemming & hawing on what I want to do. Like others have said it all depends on how much you want to spend. To go 13's I'd say you're looking at a minimum of $10k. With a radical cam (which you will need for 13's) you will need a higher stall converter.
An off the shelf one will run $300+. There is one member here that I know spent close to $900 just on a torque converter. With the compression ratio you will need to achieve 13's you will need around 93 octane if not more.
Also beware of the harmonic balancer issue as well. For more on this read this link:
http://www.explorerforum.com/forums/showthread.php?t=193059
