Hunz
- March 31, 2008
- Hendersonville,NC
- 98 XLT SOHC
Point taken, when I performed my rebuild I removed the pinion gear and installed new bearings as well as a new crush sleeve which is why i mentioned that he would need an in/lb torque wrench, but you must have not seen that. An in/lb torque wrench is the only way to "set-up" a pinion once it has been removed, but if you had performed this before you would have known. Also, anyone who has any previous experience with a rear end would have already told OP that a 4.56 is unnecessary for 33s as his main concern was if the 4.10 would be sufficient and ideal for the application. The gear swap is actually not that difficult, as I have done one on a jeep with a friend of mine. The point being you will spend more time farting around with the gear swap and money than what it is worth.
Reading manuals, threads and articles doesn't mean crap when it all comes down to it. The people who have actually walked the walked and not just talked the talk are the people you want advice from, not just spec and theory gurus
