need opinions on my plan on modifying the sync harness | Ford Explorer Forums
rusty813
Private
2018 Ford Explorer Sport
So this is what I found out after taking off the loom tape from one side of the sync harness is that the harness has to 2 plugs the black and grey connectors as seen in the picture.
1. Black connector is the sync wiring
2. Grey connector is the power oulet connectors for charger your cellphone
I found the dash harness from the same vehicle i bought the nav from so my plan is to cut off only the sync wiring system.
I was thinking of 2 options:
I can leave the wiring plug and play or i can cut off the connectors from both harness and wire it up together. Then at the end of the harness from looking at the older version of mobile which i have taken off the loom the radio connectors and radio dash harness connectors are just spliced together. which i would need to do the sync harness sync harness
Here are pictures of the sync wiring:
Sync wires
Plugs that plug into the above connectors that I plan to re-wire to above wiring
better view of the grey connector just verify that area of the wire harness is crap
