Sorry this a little long, but I figured the more detail the better.
I have a 94X that has been giving me some problems on long road trips. I was driving back from Florida last week and the check engine light came on. The truck was also having a hard time keeping up with the cruise control set at 65mph (engine bogging). The only way I could accelerate at highway speeds was to floor it and let it drop down into a passing gear which caused black smoke to come shooting out of the exhaust. My gas mileage also went from a crappy 16mpg to an even crappier 10mpg. I went and bought a code scanner and got the following codes with the key on engine off scan:
33- EGR valve not opening;insufficient flow detected
172-Heated oxygen sensor indicates lean condition, right side
182-Adaptive fuel rich limit reached at idle, right side
I was getting ready to drive from Birmingham to Chicago the next day and didn't have time to screw with it myself, so I took it to a local mechanic (of course he had to do his own scan$$$)and he said it had a vaccum leak and replaced the vaccum hose to the EGR valve. I take off to Chicago and the truck is running fine till about 300 miles into the trip. Same exact symptoms. I finally get to Chicago after stopping for gas 5 times!!!!! and take it to a Ford dealer the next day. They run the diagnostics again$$$$ and drive it around a while and can't get the symptoms to reoccur. They said that the codes they got could mean a lot of different things and that if the problems are not occuring when they run the codes, they couldn't do much. I guess I could be thankful that they didn't just start replacing a bunch of stuff and hoped it fixed the problem. So i picked the truck up, drove it for about 50 miles and I can't get it to do anything. I pack up and head back to Birmingham today and the truck runs fine till 400 miles into the trip. Same exact thing happens again, black smoke, bogging, check engine, piss pour gas mileage, etc. As soon as I got home, before I even turned the truck off, I scanned it again.
This time I did the engine running scan and got the following:
136-Heated oxygen sensor indicates lean condition, left side
I also did the key on engine off scan and got:
176-Heated oxygen sensor indicates lean condition, left side
181-Adaptive fuel rich limit reached at part throttle, right side
542-fuel pump circuit open; PCM to motor
So after all this hassle and forking out cash for diagnostic fees and gas, is it just the damn O2 sensors?????? Any suggestions/advice would be appreciated as long as I don't have to pay you a diagnostic fee
Nate
Nate
