Need some help with mods! | Ford Explorer Forums
shankomatic76
Greensboro, NC
Explorer '91 XLT
Right now i have a 91 xlt with a 2 inch spacers in the front and a couple 2" add-a-leafs in the back. After i installed the lift it looked like to me that the back of the truck sagged a little bit so i installed some 1 3/4 " warrior lift shackles, running 30" all-terrians. But now the lift and off roading bug has hit me again after a trip to forest games in danbury, nc and now i would like like something in the range of a 5 or 5.5 inch lift. I dont know weather to start from sratch and order a whole new lift kit and take the existing lift off. I'd just like to know what needs to be done and what other mods to the steering and other things i might need with a bigger lift. Thanks for Your help. :exp:
you could add a 3" body lift, and that with the lift your running would give you about 5". Or, you could go with the 5.5" lift and keep the add a leafs, shackles and spacers. You can keep the add a leafs and shackles because you will need to do a SOA in the rear. And the 5.5" coils will work with the 2" spacers. So with the stuff you have and the 5.5" lift you will have around 7.5" of lift.
