Need suggestions on lifting my Explorer | Ford Explorer Forums
Dwayne Norvell
Dallas, Texas
94 Explorer
I have a 1994 Explorer 4 door. I am planning on lifting it and would like some suggestions. I don't know much about any of this. I am wanting to go 5"-6" on it. I was contemplating on putting either a 5 1/2" susp lift or going with a 2" body lift and a 4" susp lift, as well as adding some MT 32x11.5 tires to my stock rims. What would you guys suggest and would those tires look OK on this size of lift. Thanks for all of your help.
Dngrzne!!!!....
Either way would work. You will get more ground clearance from the suspension lift, but your CG will be higher??? If you go that high you could get more than 32's under there.
