mahmoud_gh
- May 16, 2016
- 2006 ford explorer
please helppp....
2006 explorer 4.0 abs, rsc lights.
i had some times abs and rsc lights come on and car brakes by itself as traction control activate at normal driving and got b1676 and c1175.
after some time both lights abs and rsc lights keep on and only c1175 which is rear left abs sensor circuit faluire.
changed the abs sensor with new one and same problem still there.
i've checked the abs sensor connector self test voltage when turn on ignition its only 8 voltage.
other abs sensors is reading 12 voltage.
so may be poor abs module connector contacts.
tried to disconnect the abs module connector but cannot.
please help how to disconnect it with photos please if possible.
Please don't ignore and Thanks alot in advance
