Negative Battery Cable Question | Ford Explorer Forums
Seif
Hello all. I need to replace the negative battery cable in my 2000 Explorer. Is this just a straight shot to the frame or does it split off or add other ground wires on the way. I can't tell because it's wrapped up with other cables after it leaves the engine compartment.
Thanks for any input.
Jim
It is a rather small harness, it has a few wires as part of it, the starter wires etc. They are not bad at Ford still I believe, some are no longer available.
If money is tight I would have a custom cable made, they run me under $25 here for huge welding cable pieces. Regards,
